Imco Thumper power?
IMCO's "Thumper" series exhaust manifolds are very similar to their upgrade "Power Flows". The "Thumpers" are primarily meant for replacement of stock cast iron manifolds at a more affordable price point. If you're 502 is basically stock, the "Thumper" series would be the way to good and you will see some modest performance/power improvement over stock cast iron manifolds.
thanks guys, however they only come with standard risers, and on the web site they don't offer a alt, not sure if i can buy a set for the powerflow if they bolt right up, I would think they do. but unsure.
IF your old iron manifolds are leaking or bad, youll pick up some ponies and lose some weight bolting these on.
The power flows are a notch up- and have larger inner diameter runners and move more volume, power flows are a great high perf manifold for all but the wildest configurations.
UD
reason i ask is i put Imco power flows on mine last year and the 90 degree hard line that comes out of the back of the pump hit the manifold.... after doing some research i see that they make a bracket to relocate the PS pump and alternator to fix this issue ($150ish)...... would have been nice to know before every thing was installed that this might be needed....
anyway by the time i bought that relocate bracket, and then bought the brackets to mount my thunderbolt module and shift plate assembly on the other side i ended up with about and extra $200 in parts i wasnt expecting.
our pocket
