Is a steering cooler necessary? >
Old 04-01-2012 | 03:03 PM
Default Is a steering cooler necessary?
Is it a must to run with a power steering cooler? I think power steering fluid has a boiling point somewhere above 400 F.
baja_brian is offline
Old 04-02-2012 | 02:38 PM
Has anyone ever run with out a power steering cooler?
Old 04-02-2012 | 09:53 PM
mercury would not use cooler if they did not need to, easy way to reduce costs. the pump creates heat thats got to go somewhere.
keith2500hd is offline
Old 04-03-2012 | 08:19 PM
mcollinstn's Avatar
Why would you WANT to omit the cooler?
You can plumb them in most anywhere if you have space problems.
mcollinstn is offline
Old 04-03-2012 | 08:38 PM
FWIW, the pumps are automotive based and cars usually at least have a loop cooler. If it bugs you, go full manual
bustedbrick is offline
Old 04-04-2012 | 01:04 AM
I do not have a PS cooler on my full hyd system and have never had an issue. It was like that when I bought it.
Griff is online now
Old 04-04-2012 | 07:53 AM
Scarab28's Avatar
Ran all last season without one, no issues so far - Full Hyd.
Scarab28 is offline
Old 04-04-2012 | 08:46 AM
Get a tranny cooler. Drops the temp by 80-100 degrees.
$150
Keith Atlanta is offline
Old 04-05-2012 | 06:16 PM
mcollinstn's Avatar
Full hydraulic is a different beast than hydraulic assist.
Assist has a much smaller volume of fluid to heat up, and less distance to bleed heat into the "environment". Also, the bypass pressure on a full hydraulic is usually set lower than the standard popoff on the pump.
MC
Old 04-06-2012 | 12:35 AM
fireboatpilot's Avatar
RIPSTA Racing Team
So to jump in here if I may? I had the idea to take the PS cooler out of the system on the stbd engine because I think it is causing a restriction to the engine. I am not having any over heating issues but the pressures are lower on that engine. My plan was to plumb the PS cooler off of the drive pick up so water would flow only while moving. Any thoughts?
fireboatpilot is offline
