Truck tires and load ratings??? >
Old 06-25-2002 | 02:07 PM
dyno's Avatar
Charter Member #655
Default Truck tires and load ratings???
I want to put some new tires on the wifes Tahoe,something with a heavier side wall for towing, what load rating should I get?
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 06-25-2002 | 04:08 PM
Official OSO boat whore
The capacities are listed on the side of the tire. Because these are a light truck tire, the numbers are derated 10% due to a greater chance of the tire being over loaded.
Cord is offline
Old 06-25-2002 | 10:17 PM
Wildfire
They put load range E's on most 3/4 ton trucks. Be ready for the ride. We have D's on our 2500HD and they do fine, but we went up in size so they carry the same amount. Most tire websites have the capacities listed.
Old 06-26-2002 | 06:53 AM
dyno's Avatar
Charter Member #655
thanks all!
dyno is offline
Old 06-26-2002 | 07:26 AM
What tires are you running on it now Dyno?
fred is offline
Old 06-26-2002 | 08:13 AM
dyno's Avatar
Charter Member #655
I'm not sure they are the originals....B.F Goodrich, way to soft for towing my rigg...should get a big truck like yours Fred but cant see spending the money for towing it only a couple times a year...
dyno is offline
Old 06-26-2002 | 09:19 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I have the B.F. Goodrich All Terrain K/Os on my 1996 Tahoe. They are the BEST tires I have ever owned. I am right at the towing limit of my Tahoe, at 7000 pounds. I also invested in a set of Airbags for the rear, that I run all the time at 60psi, towing or not. These also REALLY helped the towing and handling characteristics of the truck.
Skater from this board owns Outlaw Motorsports in Culpepper, VA. OutlawMark works for him. They hooked me up with the bags; and can answer any of your questions a 540.829.0300.
Sydwayz is offline
Old 06-26-2002 | 09:20 AM
I would think any tire in the size range you need would be fine for you Don,.... are you going to be around Great Lakes Marina this weekend?......Fred
fred is offline
Old 06-26-2002 | 11:02 AM
dyno's Avatar
Charter Member #655
Yea Fred I'll be around... I'm on vacation starting tomarrow until July 10th.....I rented a cottage in Muskegon on the Lake .I'll be there or at the marina most of the time I'm going home monday-wednesday next week Rachel has to work....I'll be digging into my milky oil issues and have a few other projects I need to get done around the house. I need a ride in the new whale....
Don
dyno is offline
Intolerant1
Check www.tirerack.com for feedback on the tires they have listed. I bought my last set there. Stay away from E load ratings unless you really need it. Very harsh ride.
