Header is hot on one motor >
Old 04-03-2012 | 10:57 AM
Spidey's Avatar
Default Header is hot on one motor
Hey out there. I have a 382 with 700's and I have one header that is worrying me. On the port side of the starboard motor, one of the header pipes is too hot (in my opinion). I can touch all the other header pipes without any trouble after a run, but one pipe is so hot you can't keep your finger on it for more than a second or two. Is this normal? Do any other folks out there have this issue? Anything to do about it or am I just overreacting?
Spidey is offline
Old 04-03-2012 | 11:10 AM
Sydwayz's Avatar
Forum Regulator
How is the water flow compared to the others, out the tips?
What is the condition of the impellers?
SmartCraft ought to alert when one side gets too hot. Have you hooked it up to a scanner to double-check?
Sydwayz is offline
Old 04-03-2012 | 11:16 AM
Spidey's Avatar
I had this problem last year so I had the impellers changed in the off season. Water flow from the tail pipes seems to be the same to the naked eye.
Spidey is offline
Old 04-03-2012 | 11:55 AM
buy a $30 heat sensing gun from harbor freight tools. Good for checking wheel hubs on ur trailer too.
drpete3 is offline
Old 04-03-2012 | 12:31 PM
C_Spray's Avatar
Diamond Member #001
Could be some debris caught in the main heat exchanger, partially blocking that side. Can you get to the end plates on the main HE and look inside?
C_Spray is offline
Old 04-03-2012 | 08:45 PM
CMI has made a new recommendation for the sweepers "headers" on the 700's. I think I have the hump hose completely closed off so all the water goes through the header? Call them to check on the latest.. Did you notice...at the miami show the new merc 525 replacement now has a header temp sensor where the header collector connects to the tailpipe....handy I thinks
fossil fuel is offline
Old 04-03-2012 | 09:43 PM
Sydwayz's Avatar
Forum Regulator
The laser temp gun won't fix anything, but it will allow you to pinpoint hot spots. It will allow you to find a hot cylinder if that is the case. They are priceless tools.
Sydwayz is offline
Old 04-04-2012 | 11:19 AM
Spidey's Avatar
Thanks. I have a couple of good tips that I will check out. I'll let you all know what I find out.
Spidey is offline
Old 04-07-2012 | 12:53 AM
I checked today and the lower feed from the header distribution pipe to the bottom tailpipe feed is now blocked off per merc. They want all the water to flow through the header, through the hump hose and into the tailpipe from the top. I put a 2nd hose connection for flushing on the transom. In low water pressure areas I can flush with two hoses into one motor. It matters when your strainers get sucked dry the water is not reaching the top of the upper header pipes.
Old 04-07-2012 | 10:41 PM
Spidey's Avatar
My local speed shop also has told me about blocking off the lower tailpipe feed. I am having this done to my headers ASAP. But, tell me more about your flushing system. Send me a pic or explain it again please. Thanks.
Spidey is offline
