Oil filter change question >
Old 04-05-2012 | 06:55 PM
Default Oil filter change question
Question on how hard is it to change the oil filters on 350 small blocks in a 272LS with through hull exhaust? Getting parts together to put the motors back in and considering going with the remote oil filter kits. Would add about $100 to the project cost. Doesn't seem like much, but everytime I turn around it is another $50 to $300.
AND YES I KNOW WHAT BOAT STANDS FOR!!!!!
sorry for yelling
Feedback? Do you curse and swear everytime you change them? Do you change them every time? Never thought about that, good large filter seems odd to change it every 30 to 50 hours, but that is how long people run before changing oil it seems.
Thank you,
Brian
befu is offline
Old 04-05-2012 | 07:26 PM
Are your oil filters not on the manifolds ? this is how our old 272 was !!!!
formula 382 sr-1 is offline
Old 04-05-2012 | 08:20 PM
The old motors had them right into the bottom of the block, stock location. Doesn't seem like much fun to change.
Brian
befu is offline
Old 04-05-2012 | 09:17 PM
Brian,
Don't cut corners on this....do the remote mounts. On my 255 I couldn't even see my oil filters...much less get to them.
sprink58 is offline
Old 04-05-2012 | 09:48 PM
Alrighty! will order them.
what oil filter do people run? I mean, this is only a 300 hp small block, not real high strung. Just run a quality filter like a mobil 1? Really, I do not know.
Brian
befu is offline
Old 04-05-2012 | 10:49 PM
Yes install them and put them in a spot that is easy to get to and clean up if you spill any when you replace them !!!
Old 04-06-2012 | 08:42 AM
I would also order a couple of ez drain oil kits, this was you can just pull them threw the drain hole no more mess in the bilge!!
http://www.keitheickert.com/p-13338-...20-thread.aspx
86242ls is offline
Old 04-06-2012 | 09:03 AM
Mentalpause's Avatar
Does anyone actually drain their oil into their bilge. I would think putting one of those kits on after the engine is in the boat would be a PITA.
Much easier just to get a jabsco oil drain pump.
http://www.westmarine.com/webapp/wcs...ord=oil+change
Mentalpause is offline
Old 04-08-2012 | 09:00 AM
randymbtech's Avatar
Where can you buy the remote mounting kits? If you buy that stuff from Mercruiser, it is almost $100 for each oil line, and the adapter that bolts to the block is like $350! And thats just for one motor!
randymbtech is offline
Old 04-08-2012 | 09:31 AM
yes, I am putting remote drains on. Want to be able to pull the hose out through the bilge drain and then drain the oil. With the motors out, this is an easier project.
befu is offline
