Prop Question
Old 04-10-2012 | 06:24 PM
Default Prop Question
I've got a line on a set of props for a pretty good price ( I think), but I don't know a lot about props so I was wondering if a visual is good enough to be sure they're ok or is there some other things I should check to make sure I'm not getting rooked? They're a set of BIII 24p.
Schnook is offline
Old 04-10-2012 | 07:21 PM
Dave M's Avatar
Veteran: Navy
A few GOOD hi-res pics is usually good enough for me for a stock prop anyway. I've bought and sold props, no issues. My radar goes off when I see "labbed".
Dave M is offline
Old 04-10-2012 | 07:39 PM
Rookie's Avatar
Not being a smartazz but you do have BravoIII outdrive, right?
Rookie is offline
Old 04-10-2012 | 08:16 PM
Ha! not smartazz at all, I think we've all been bitten in the arse by the simple details. Yeah, BIII, just never bought props before.
Schnook is offline
Old 04-10-2012 | 08:24 PM
Ok that brings up another question why do you have a bravo 3 on a 27zx??? Doesn't seem like the right drive for that boat.
Also not trying to be a smartazz
pstorti is offline
Old 04-10-2012 | 09:13 PM
That's what it came with when I got it, which is actually a good thing, sort of. Don't want to invest the $ it would take to make this single engine pig go really fast, I shoulda got one with twins and steps. So a B III gives me fairly decent performance up to about 45 - 50. At least that's what I tell myself to feel better when everyone else is blowing by me. Probably switching to a cruiser next year anyway.
Schnook is offline
Old 04-12-2012 | 10:29 AM
teaguecustommarine's Avatar
Offshoreonly Advertiser
Bravo III's are good drives! They are very quick on the bottom and range for bigger, heavier, less powered boats. They also steer very well and are actually pretty strong!
The real question is, what props do you currently have on there? Are your props destroyed?
For most Bravo III set ups, i usually recommend to replace with what is on there unless you need to gain or drop RPM. I would no necessary recommend "labbed" B3 props because there will be no real advantage to the thinness and cup on a counter rotating set up (most of the time)... -Eric
TEAGUE CUSTOM MARINE
661.295.7000
www.teaguecustommarine.com
teaguecustommarine is offline
Old 04-12-2012 | 10:42 AM
Make sure they are matched before install.
( im sure thats pretty obvious )
but I had a bunghole off ebay selling 30s
ship me a 28 & a 30. When I called he said the 28 was ”worked” to a 30
scarab63 is offline
Old 04-12-2012 | 01:08 PM
97FASTech's Avatar
Veteran: Army
Ask the seller if they ever were repaired for dings, dents, and cracks. Normally if the props were repaired, they will have a stamping on them, with a letter and numbers.
97FASTech is offline
