transom mount hydraulic steering >
Old 04-11-2012 | 05:01 PM
Default transom mount hydraulic steering
I'm looking for a transom mount (center) hardware for a marine machine steering systeme or maybe other brand latham, imco ...
Perf langlais is offline
Old 04-12-2012 | 10:53 AM
resurrected's Avatar
I have Marine Machine Wing plates for Mercury Bravo outdrives and tie bar for twin engine hydraulic set up. This set up is extremely heavy duty with 1 5/16" diameter tie bar that is 54 3/4" center to center. This is perfect for a medium size cat with bravo drives. The tie bar can also be shortened at your local machine shop at minimal expense to fit any twin engine application. Steering rams can be attached outside or inside of the wing plates on this set up. I do not have the long studs to mount them to the bellhousings. Other than those, I am in Owen Sound ON. I will take $500 and you pay actual shipping.
resurrected is offline
Old 04-12-2012 | 11:01 AM
Sick Stinger's Avatar
Brotherhood #1
I have a Mayfair steering system all but helm unit. would need another wing plate for the twin application. Rams thru hulls stainless braided hosed bolts transom mounts and inner blocks. 7inch rams
-Mike
Sick Stinger is offline
Old 04-13-2012 | 04:19 PM
Thanks but i already have the cylinder and the wing plate. Im looking for transom mount to complet my setup
Old 01-03-2014 | 09:41 PM
Hello -saw your note and wondered if there was any twin TRS external hydraulic steering setups in your neck of the woods for sale.
I am located near London, Ontario
Thanks for now
Ron Smith is offline
Old 01-04-2014 | 11:18 AM
Ron, I sent you a pm.
payuppsucker is offline
