Livorsi control install question? >
Old 04-12-2012 | 11:04 AM
Default Livorsi control install question?
I am getting ready to swap my oe offshore control for a billet Livorsi control. I believe the oe one is just the stadard Kiekhaefer control? Anyways, I am a little worried that I am going to have trouble getting the new throttle adjusted correctly, or should I be able to unbolt my oe control and bolt in the new one? I am fairly mechanically inclined, but I have never pulled pulled controls before. Should I just have it installed for me? Or is this somethign I should be able to do myself?
Old control-
New Control-
MCKILLOP is offline
Old 04-12-2012 | 12:29 PM
They are easy to adjust. You can get them pretty close at the control and then do the final adjustment at the other end in the bilge.
Griff is offline
Old 04-17-2012 | 07:51 PM
nice conrtol! same size as your o.e? as far as mounting base goes. that's the only problem i see, should be almost plug and play as Griff stated.
Meara_Image is offline
Old 04-18-2012 | 12:43 PM
Pictures are deceiving. Same size base and mounting holes.
MCKILLOP is offline
Old 04-18-2012 | 06:03 PM
Go to it! and keep us posted!!! what a face lift it will be from the o.e controls!!!
Old 04-18-2012 | 08:55 PM
Thanks. I have the matching wheel and gauges installed as well. Should look a lot better
MCKILLOP is offline
Old 04-18-2012 | 09:20 PM
Rookie's Avatar
Did you purchase the red and clear switch covers?
Rookie is offline
Old 04-19-2012 | 01:25 AM
I was going to say a wheel and some gauges would look SICK to go along with that shifter!! Wise choice to add some color! I'm digging it!
