Anyone know how to remove hydraulic stud on k-plane >
Old 04-12-2012 | 01:13 PM
Default Anyone know how to remove hydraulic stud on k-plane
I think I need to replace my upper k-plane mounting plate due to some corrosion in the hole for the indicator cable. Does anyone know how to remove the thru-hull hydraulic studs so I can re-use them? Anyone know where I can get the upper plate for the least amount of money?
FBRONCO is offline
Old 04-12-2012 | 08:13 PM
Anyone?
FBRONCO is offline
Old 04-12-2012 | 11:30 PM
Might be cheaper to just hace the corrosion ground out and then weld in the damaged area and have it redrilled.
Griff is online now
Old 04-12-2012 | 11:53 PM
c_deezy's Avatar
They should just screw out from the boat side of the plate. Just take off the plastic nut on the outside, then turn them out. May need a pipe wrench.
There were some k-plane plates in the swap shop for a decent price.
c_deezy is offline
Old 04-13-2012 | 01:47 AM
sac
Snap-on makes a collet type stud puller, they work excellent.
sac is offline
