blower carb tuning HELP >
Old 04-12-2012 | 01:15 PM
Default blower carb tuning HELP
Hello all over winter a have been searching the net and talking to fellow racers and have found alot of advice here so i decided to join first off im not a boat guy please dont hold that against me i am a drag racer i have a tube chassis altered body that only weights in at 1500 ibs FIRST drag racers frown on blown gas they seem to think if it has a blower it should be injected alky never get any help from them i see u guys make it happen so hope i can get help i like to be different and do things noone else normal does i am running a 427 sbc with dart pro1 heads dart block with 9-1 compression msd dist with msd 10 ign box tall manifold to clear regular dist a 14-71 mooneyham large opening turning 1:1 with adapter to accept three - 750 holleys pn#4779 mech secondarys four corner idle no power valves pro series aeromotive fuel pump damn big one all -10 and -8 fuel lines 30 degree timing 118 octane fuel use to run with 2- 750 on a 6-71 for years like that and was great switch to 14-71 and three carbs and been nothing but trouble it idles fine surges but dont matter to me sounds strong runs slow as hell acts like too much fuel i started with my old jetting of 88 squared and now down too 70 squared and still egts cold bout 800 degrees and still blowing black smoke and flames out zoomie pipes any ideas? more timing needed? how does 3rd carb causing rich condition? im afraid of going lean and burning it down been there done that any help would be greatly appreciated i tryed remembering to include all info but sure i forgot something thanks in advance tony
finfrock29 is offline
Old 04-12-2012 | 09:05 PM
Your about 200 cu.in. small for that much carburation !!!! Being an x drag racer I have to ask why gas ? Alcohol is so much cheaper and much more tuneable . just saying
Jeff P31 is offline
Old 04-12-2012 | 10:39 PM
Im stubborn and have everythin to run on gas 118 fuel is 8 bucks a gallon so cost not much diff how bout using center carb for just air? the way i looked at it if i had two 1050s on a 14 71 that be better?
Old 04-12-2012 | 11:23 PM
I have never seen any boat engine run 3 carbs and that includes 600ci + stuff. Like was said, you have way too much carb, especially for a 427.
Griff is offline
Old 04-13-2012 | 01:07 AM
you need to go to 2 carbs,and bump the timing up to 34 deg.with the right tune up,you can make good power with race gas.
mike tkach is offline
Old 04-13-2012 | 01:17 AM
Just takin fuel away from one out of question? Spent alot of time making that stupid adapter hate to see it scraped just askin tho dunno if adapter can be bought for large openin and really dont have the time to make another
Old 04-13-2012 | 01:44 AM
sac
I saw a boat in Key West in 1995 with 3 dominators with huge Wipples, 46' Skater with Arnesons, prolly had some huge cubic inch motors, so it has been done. 427 cubic inches you might try triple 600 cfm carbs.
sac is offline
Old 04-13-2012 | 02:47 AM
Thanks for reply i was just thinkin an injector hat has more cfm than im using and in theory it would work fine gotta get it figured out sooner or later
Old 04-13-2012 | 12:25 PM
Take 1 carb of and cover the hole with a plate . As for injector hat's they come in all different sizes as well . How much boost are you running with the 14-71 ? Just seem's way over kill for a 427 cu. in. Good luck
Jeff P31 is offline
Old 04-13-2012 | 05:57 PM
15lbs at 6800 rpm max
