6.2's what about them
I think they are decent, How many hours?. Run in salt you will need exhaust if not done already. Fresh and I would pull a riser and check. They have there little quirks, like carry a spare I.A.C valve. Other than that I really have had no issues and I have about 320 hours.
It will probably need bellows if they have not been done yet,and if they are bad gimbal bearings.
expensive date is spot on....
check risers and temp sensors for corrosion. Bellows should get attention if they haven't been changed.
X2 on the IAC. I have had mine go too.
In another 80 hrs..the top end should get looked at (lifters, springs, valves, etc). Simple compression test will let you know how the bottom end is holding up. Plugs and cap should get looked at too.
We have 480 on ours.
