If we are talking Hering here.. >
Old 04-16-2012 | 08:56 PM
Default If we are talking Hering here..
What prop has the least amount of vibration? 5 6 or 7 bl.
( hubbed style )
mcprodesign is offline
Old 04-18-2012 | 02:12 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Theoredically there is less vibration with 7 blades.
However, variables involving the load on the high pressure side of the blade has to be concidered. X dimention water quality are issues that can affect this.
Brett
[email protected]
bbladesprops is offline
Old 04-19-2012 | 01:13 AM
Might as well have 2 sets of props . I'm going to go the Hering route for the second set (incase I brake a prop.) Thanks Brett. And thanks foir the hook up on the props
Old 04-19-2012 | 09:47 AM
Smile
Your welcome,
Let me know if you need help with the Hering props. We are a authorized sales and repair facility for them. Our pricing might surprise you.
Also, before concidering 7 blade propellers, I would want to talk to you about it.
Thanks,
Brett
[email protected]
Old 04-19-2012 | 11:27 PM
I'm guessing my X might not be high enough for 7 bl. There's a set of 6 bl in the classifieds for 2700
Old 04-20-2012 | 10:28 AM
Smile
Why so cheap?????? hmmmmm
6 blades have a ton of stern lift too.
I believe 95% of all applications will run their best with 4 or 5 blades when set up correctly.
Brett
Dosen't mean they wont work and that testing shouldn't be done. I always tell people to test every propeller they have the opportunity to test
[email protected]
Old 04-20-2012 | 10:45 AM
Stern lift might be what I need to get on the two steps as much as possible. I do want less cupping to make my drives endure less pain ! > I might have a set to try at desert storm.. If they work I may be going on the Prop rental program w you
Old 04-21-2012 | 01:56 PM
I guess he was tired of tire kickers
