Splashed the 260 this last weekend >
Old 04-17-2012 | 06:45 AM
Default Splashed the 260 this last weekend
I finally got the 260 in thwe water this weekend. Ran great! Went to Gilligans and toured around the river a bit. Had a few issues outside that that need to be addressed though. Need a new power steering actuator (mine puked steering fluid ALL over the bilge) and the rotor assembly in the trim sending unit had the teeth sheared off.. ? Strange one. Have new parts for all on order.
The gauges all proved out good and the GPS speedo is working as designed. New stereo rocks!
I ran the prop I got back from BD. I was disappointed. Top speed was only 64-65 MPH at 5000+ RPM. I was at 40MPH at 3500 RPM. That prop came back from BD with a 24p and was 14.75 inches in diamter. I think the previous owner had it cut down in pitch and diameter in order to tow skiers and for watersports. Irregardless, I am trying to get in touch with Brett at BBlades to get a new prop. Hopefully that will get me back in the mid-70s. Kenny H told me I should be able to almost see 80 with my engine with a properly labbed 28p Bravo 1 prop, 1/4 tank gas and one person on board, but I am not going for top speed.
Any suggestions on props (based on what I said above)?
Thanks!
Redhook98 is offline
Old 04-17-2012 | 01:19 PM
Revelocity's Avatar
I guess you are now hitting your rev limiter? I'd go up one pitch size first as I think 28" Bravo would be a bit steep for every day. I'd also try a 24" Hydro Q4 also which is about the same as a 26" Bravo since Bravo overstates pitch.
Revelocity is offline
Old 04-17-2012 | 02:24 PM
The prop currently on the boat that I am referring to as a 24P is a 26P Bravo that was tweaked by the last owner. I said in my first post that it is a 24P, but it is a 26P that was retouched to a 24P between the last owner and BD Props. The Prop Scan came back saying all 4 blades were 24P. You can not feel even the slightest cup at all either.
Going to try a new Bravo 26P. The adding of the cup and 1.3 inches of pitch should give me a better daily use prop.
Old 04-17-2012 | 03:51 PM
Try a 28p Bravo 1. With the 496 HO the 290SC leaves Velocity with a 28 bravo 1 that is slightly worked. RPM and speed are 4800-5000 and 70-73 mph, respectively.
modvp is offline
Old 04-17-2012 | 07:14 PM
What horsepower?
Revd Up is offline
Old 04-17-2012 | 07:51 PM
i have a 28p bravo1 on my 260 with 496mag and see 72
gotstreetracin is offline
Old 04-18-2012 | 01:59 AM
Originally Posted by Revd Up
What horsepower?
I have the 496 HO (425 HP)
Old 04-18-2012 | 02:02 AM
But what is your hole shot like, and how many people can you have onboard and still pull decently out of the hole? Looking for best all-around daily-use prop. So far it seems to be the 26P Bravo I. The 28P that Velocity puts on them from the factory are labbed. I do not want to go that route. Anyone have a Hydro on theirs?
Old 04-18-2012 | 04:13 PM
i have a stock hydro 27p 4 blade on my 260 with a 500efi. best of 78 gps in fresh water, i do like how the prop planes of fast and handles well. I am going to look for a bravo 28p to try just to see, the only other props i have had on it were a mirage 27p 3 blade and a hydro 28p 5 blade. The 3 blade had to mutch slip and was a litle harder to get on plane, the 5 blade was nice but i think its a big part of my drive blowing up.
rmfriday is offline
Old 04-19-2012 | 01:27 PM
This is the guy in the know with Velocity props. I got 4MPH with my hydro afteer he worked it. He has a velocity and knows what they like and need.
Halls Propeller Service
24700 East Colonial Drive, Christmas Florida, FL 32709
(407) 568-5506 ()   (321) 363-7521 (Mobile)
Waterslinger is offline
