Parts washers..... What do you use in yours? >
Old 04-18-2012 | 09:12 PM
Default Parts washers..... What do you use in yours?
I just bought a parts washer for my new shop. I have never had one before; always just used degreaser and brake cleaner. The shop I rented had tons of nuts and bolts sets that I need to put in organizers and I want to clean them up before storing them. What does everyone use in their cleaners? I have access to K1 and mineral sprits readily. Only issue with those is the oily residue they leave afterwards. Someone suggested doing a "dip" in a degreaser solution after the parts cleaner to remove he residue. Any input would be greatly appreciated.
FuelinAround is offline
Old 04-18-2012 | 09:15 PM
i use mineral spirits,have for years.
mike tkach is offline
Old 04-18-2012 | 09:33 PM
Ditto
shark42 is offline
Old 04-18-2012 | 09:43 PM
I use mineral spirits then spray off with hot water. Removes the oily residue. Really works well.
snapmorgan is offline
Old 04-18-2012 | 09:48 PM
Thanks guys... We used to carry odorless ms... Will see if we still do.
Old 04-18-2012 | 09:54 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Use mineral spirits a work, mainly because it's cheap and does a pretty good job.
Used to use Stanisol (sp?) at last job. Works 10x better. Not sure if that can be purchased by anyone. We had a service that supplied and changed out the cleaner every so often.
US1 Fountain is offline
Old 04-18-2012 | 10:16 PM
Expensive Date's Avatar
Sometimes the guys that go around to shops and service the parts washers forget there lunch money..........Just sayin.
Expensive Date is offline
Old 04-18-2012 | 11:24 PM
I have my "dirty" parts washer serviced every few months by Crystal Clean (like Safety Kleen) with a degreasing chemical. It works great but smells like crap. We all wear gloves whenever we use it. The "clean" washer uses mineral spirits. I don't find it leaves a residue.We also use mineral spirits in a siphon gun to wash blocks, cranks, etc. Anything that won't fit in the washer.
Eddie
Young Performance is offline
Old 04-18-2012 | 11:36 PM
nothin' cleans parts like a little gasoline.
SDFever is offline
Old 04-19-2012 | 01:20 AM
Diesel fuel works well also. That's what I use in mine.
Likefastboats is offline
