stepped hull and boat hoist >
Old 04-20-2012 | 07:58 AM
Default stepped hull and boat hoist
im looking at a boat hoist this year for my boat. 38ft zx donzi with a stepped hull. The hoist just has stright bunks. How bad is this on my hull? Would i need to just the hoist to fit the steps or would it be ok cause its just a slow lift out of the water?
prostock3 is offline
Old 04-20-2012 | 08:09 AM
Fix the bunks to match your hull. Point loading the steps is not good and hull damage will occur. Just because you lift it out slowly doesn't change the weight load on the hull relative to the bunks.
Search the forums, tons of info on how to modify bunks for step hulls or contact a company like Myco that will build you a cradle.
techman is offline
Knot 4 Me's Avatar
The bunks need to be modified to properly support the hull.
Knot 4 Me is offline
Old 04-20-2012 | 08:33 AM
Sydwayz's Avatar
Forum Regulator
Just discussed a couple days ago, can be found with a search.
You do need to make the bunks fit the boat.
Sydwayz is offline
