bent prop shaft on bravo 1
Bill what the hell!!!!you get it back on the water and you hit something?????I thought Mike had bad luck...Did my valve covers work out for you??If they did you can send me a check
Don Veldink
2036 Breeze Dr. Holland Mi.49424
if not just drop them off at my Dads whan you get a chance...
Don
Don Veldink
Don
If your boat has a sail do you ride a horse to the ramp?
Just had to replace both on my 96' Bravo I's thanks to a rock in the Florida Keys. Shafts are about $450. Shaft, seal kit and labor: $1,000 per side. I believe that I read you were considering having a mechanic straighten the shaft, not worth it in my opinion. Any runout and it will cause premature wear on the seal, never mind the vibration and subsequent potential damage to the rest of the drive. I just had to suck it up and replace 'em. This is a great link:
riskhttp://www.mercruiserparts.com/Show_pictures3.asp?dnbr=809808%2096&ivar=images/CRUISER/809808.96/8.png&inbr=1943&bnbr=22&bdesc=GEAR+HOUSING+%28BRAV O+I%29
It will give you an idea on prices.
Mike
Mike
