Oil Pressure to low? >
Old 06-27-2002 | 12:08 AM
1Gunner
Default Oil Pressure to low?
My new 383 sbc has 5 hrs boat time on it running 20-50 oil with a Milodon Oil System.
Thing is all I see is 40 psi pressure, whether it's idling or running 5200 RPM.
The engine builder tells me 40 is just fine as it's a high volume system...... does this make sense??
Any thoughts???
thanks
Old 06-27-2002 | 12:21 PM
jdnca1's Avatar
There are definately two schools of thought on "ideal" oil pressure. Both "schools" have valid points so I think it comes down to builder preferences. As fellow OSO'r Wette Vette (A mechanical engineer and fluid dynamics guru) has pointed out to me, make sure you understand the differences between pressure and flow. At 45 PSI you'll have more flow of oil through the bearings than at 60 PSI. Is that good or bad, Thats why I leave it up to the builders, its over my head.
jdnca1 is offline
nauticaL ILLUSIONS
7
05-31-2008 08:13 AM
GoCiggie31
7
08-19-2007 06:07 PM
FlyFast
13
05-10-2004 11:39 PM
jimjomack
6
09-08-2003 02:31 PM
birdog
15
06-26-2003 11:44 AM
