Need to attach something to the inside hull
I am recarpeting my 97 Scarab 22. I took about a two foot tall section of carpet off the sides of the interior. I kinda figured that there was not much material between the inside and outside of the boat on the sides.
I was hoping to attach a nice small cargo net bag on each side for wallets and things but how. Is it safe to adhesive a peice of wood the side of the boat, cover with carpet so I can screw to it?
yep, no prob. About the worst that can happen is it could print through but its highly unlikely at that depth.
08 OPA High Points Champion
I would use a mix of epoxy and west systems 404 to a thick paste, not a bad idea to put a layer of glass over either. Print through is when you can see the shape of coring or laminates in the outer skin, it is usually a function of different rates of thermal expansion/contraction. Its nothing structural and the thinner the more susceptible the laminate, I doubt you will have any issues though.
