Pressure testing manifolds >
Old 04-27-2012 | 12:46 PM
Default Pressure testing manifolds
Is it ok to pressure test my alum exhaust manifolds with my (residential) hose? It probably has 40-50lbs of pressure.
FBRONCO is offline
Old 04-27-2012 | 02:25 PM
I didn't think home pressure was that high, mine is @ 15 psi
johnnywhale is offline
Old 04-27-2012 | 10:02 PM
That is A LOT of pressure, I'd vote NO. On my Stainless Marine manifolds, there was probably 100sq.in on either side of the casting, you're looking at 4-5000 pounds of force. I'd pressurize to a couple psi, with air, maybe a bike pump, and dunk the manifold in water, look for bubbles.
bustedbrick is offline
Old 04-28-2012 | 01:00 AM
Huh????? That is like saying you have 1000 square inches of plumbing in your in your house and there is 50000lbs of force.The force is spread out.
It is still 40-50psi and a good set of manifolds can handle that pressure with no problem.
Griff is offline
Old 04-28-2012 | 03:17 AM
Default testing exh manifolds
I had the first gen stainless marine bbc manifolds and that is exactly how I tested mine. My water pressure built up to about 30 psi.
BTW--on mine, the aluminum bottoms were fine and I found a crack in one of my ss riser pipes (the inner pipe).
Good Luck, FT
Flying Tomato is offline
