Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
K-Plane thru-hull fitting removal >
Old 04-29-2012 | 04:53 PM
onesickpantera's Avatar
Default K-Plane thru-hull fitting removal
Thought I would post this here too since many here would be dealing with this.
Are the thru-hull fittings for the hydraulic lines pressed in or threaded? I put a little heat to mine and leaned on it pretty good with a pipe wrench and it didn't budge. Don't want to get any more aggressive if it's pressed in.
onesickpantera is offline
Old 04-29-2012 | 04:57 PM
Biggus's Avatar
Mine were threaded in.
Biggus is offline
Old 04-29-2012 | 09:22 PM
Curious, why are you needing to remove? Can you leave it as is?
Holy Smokes is offline
c_deezy's Avatar
They should be threaded. Mine were, 3/4 inch rough thread if I recall.
c_deezy is offline
Old 04-29-2012 | 10:13 PM
Mine are threaded. Just had them out last week. They get corrosion from dissimilar metals. Stainless into aluminum. If the don't come out with a little heat and penetrant I would leave them in.
baja208 is offline
Old 04-30-2012 | 07:36 AM
I can if I have to. I am moving the tabs and wanted to do a test fit without making a template. Plus I was thinking about having them powder coated a different color. But, after seeing the factory coating and how thick it is I may skip that.
