Gaffrig Superflo 4.5" mufflers
I have two pairs of these. These mufflers worked AWESOME to reduce the noise when closed. These were freshwater mufflers, so no salt rusty junk. However, one of them has a little cosmetic damage, from the upper tie bar hitting it. Doesnt affect the operation, just cosmetic. Im sure a stainless welder can pretty that one up a bit, or just run as is. I'll try to get some pics tonight.
They come with all air cylinders, and I believe i have a pump for them. These can be made to work on a 4" tip setup also.
I'll take 900.00 for everything plus freight.
Heres a link to the superflo's. 2884.00 new from Gaffrig.
http://www.gaffrigperformance.com/Pr...SubCategory=13
I do have a pump. Its been sitting for a while, i put power to it and it worked. This wouldnt be a bad deal for ya, since you'd have a nice set with extra set in case you needed a air cylinder or other part.
If H2X takes one pair plus the pump, I may be interested in the other pair. I already have a pump from my Silent Choice setup. I may even take the one with damage, depending on how bad it is. Need pictures. How much will you want for the pair?
Thanks!
Thanks!
