Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Recommendations for Gelcoat repair >
Old 05-01-2012 | 10:39 AM
Default Recommendations for Gelcoat repair
I had the speedo pickup ripped off the back of my boat by an unmarked fishing net. It ripped the screws out and messed up the gelcoat. It's a small spot so I thought I would try the repair myself. Any recommendations on product and technique would be appreciated.
ThisIsLivin is offline
Old 05-01-2012 | 05:22 PM
glassdave's Avatar
Neno the mind boggler
Its a lot like filling screw holes, heres a post i put up in another thread with some pics.
http://www.offshoreonly.com/forums/2697305-post29.html
How concerned are you with color that far down? You might be able to get away with a white gel paste but will most likely show a bit. Are you re installing the pickup?
08 OPA High Points Champion
glassdave is offline
Old 05-02-2012 | 07:58 AM
Thanks for the tip, I will be reinstalling the pickup so you wouldn't see much of the repair and only when it's on the trailer so an exact color match isn't important. What do you recommend for product?
Old 05-02-2012 | 08:22 AM
glassdave's Avatar
For gel i think they have small gel paste kits at West Marine that should fill the bill. I like West Systems 404 high density filler if you are going to re set a screw.
