575 SCI upgrades
I just picked up a new to me boat with a 30hr 575 in it. Looking at Whipple's website, I see that they offer a kit to take it to 700hp. Consists of an intake with a chiller and a smaller blower pulley, belt and tune. Has anyone tried it and how did it work out? Still looking for dependability. Seems a bit pricey for basically a manifold and pulley. Is there a better bolt on option? Anyone have a used setup that they removed when going bigger?
Yes, I have the WC-9062B Hi-Performance 575 SCI Performance Kit with a 3" pulley. Do I think I'm getting 700HP...no. When I did the conversion, I had 200 hours on the engines. I did see a fairly large improvement on hot and humid days, 75-76 GPS vs. 80-81 GPS. There are so many variables involved, that it is "exactly" hard to gauge the "top end" improvement. Would I purchase the kit again ...yes, as there is a noticeable improvement in all around performance.
This was prior to my Arneson conversion.
We are finishing mine up right now. Before adding any more boost I would check head gaskets. I went back with Fel Pro MLS. Those or Cometics would be my choice. I also added ARP head studs for additional insurance. I also upgraded to hydraulic roller cams. Will see what dyno says.
I will do the cam, head upgrades at rebuild time. But this is a 30hr engine and I am not ready to pull it out just yet with summer fast approaching. I am interested in a proven package that won't have to go to the dyno.
I did the Superchiller. It came with a 3.5" pulley and no ECM mods. It works great. Head gasket blew 50hours later. Fixed that, on both engines, and a cam busted shortly after. Rebuilt both engines. Went roller cam, .030, and head and block clean up for minimal more compression. Still no ECM changes. They've run great the last 200+ hours. If you do the pulley, DO the head gaskets!!! Take care of the blower bearings too!!! I change the oil every 25 hours and change the bearings at 100. They've always looked great.
On the 250/256 blowers gas dilution can be an issue so check and change often. They are not real picky on what gear oil you use in them. With 30hrs I would check it and change it with what you have on hand. The rear bearings are sealed on later models with the only maintenance being done at rebuild time (wouldnt run them more than a max of 200hrs before rebuild). The head gaskets are only good for about 200hrs as well.
My 2001 575 was very rich out of the box. I ran a 3.5" pulley and a 120* thermostat with quite noticeable gains and did not remap...BTW, I have a 3.5" that I will sell you...they are getting hard to find.
As far as an the whipple kit you still should check and see how much hatch clearance you have as hatch modification adds even more cost. You may want to consider upgrading the whole blower package as the low hour blower you have is in quite high demand for guys that have to replace one and want it to match their other motor. It would sell for a premium. This is the route I took after replacing the 256 once and then the rotors touched on the second one. I was able to rebuild and sell the second one. I did end up going with a whipple lowpro innercooler and an 871 littlefield on top of that utilizing the stock fuel injection. I had an ECM mapped by EB marine in Tennessee copying a guy who had about the same setup. I also added an adjustable fuel pressure regulator so I could bump the fuel pressure up if needed. I am now running 9lbs of boost with the 871 slightly overdriven. I have also upgraded my headgaskets .
If you have any questions let me know
