Installing Gil Style Stainless Risers >
Old 05-04-2012 | 04:34 PM
Default Installing Gil Style Stainless Risers
I am installing my stainless Gil type risers on stock Mercruiser manifolds.
I have the gaskets, I am thinking I use that Blue Gasket Sealant on the manifold, then put the gasket down and more Blue Sealant on the gasket, then put the Riser down and tighten up.
I am going to use hardened (Black) bolts with lock washer/washer combo.
Sound right?
VancouverMark is offline
Old 05-04-2012 | 10:48 PM
What kind of stock Merc manifolds???? Not sure exactly what you mean by "Gil type risers." The only manifolds those Gil risers will fit are the aluminum Merc manifolds that were made by Gil that were used on the HP engines.
You do not need to use any sealer on the gaskets and I would not use any. I would use stainless bolts and SS flat washers only and put some anti seize on the threads of the bolts. They only need to be torqued down to about 30-35 ft lbs.
Griff is offline
Old 05-11-2012 | 11:38 AM
So gil made maniforlds for mercruiser? Are they any good?
TDSracing is offline
Old 05-11-2012 | 11:48 AM
The manifolds Gil made for mercruiser are the exact same as the regular gil manifolds except they cast "mercruiser" on them.
Baja226sport is offline
Old 05-11-2012 | 11:52 AM
The Gill Manifolds are some of the best manifolds you can buy for a mild BBC.
MCKILLOP is offline
Old 05-11-2012 | 05:01 PM
there are some "gil style" risers out there made to fit on stock merc 260-330 style manifolds. there is very little to be gained. the power loss in stock merc manifolds is primarily the 2.1 by 2.5 inch hole on top of the manifold. if trying to run hotter cams so you need more dry riser length, and if they weren't gotten for full retail, they could be a good idea. they also look pretty.
dereknkathy is offline
Old 05-11-2012 | 05:58 PM
Default fixx
dont forget the turbulators or you will get water on the valves when they sweat..
FIXX is offline
Old 05-11-2012 | 07:59 PM
I just bought a boat and think mine has these. They are pretty large, have mercruiser cast into them and stainless GIL risers with switchable mufflers on the tips. They also have the hoses at the bottom connecting each. To the original question, mine look to have grey gasket sealer on them. The same is on my intake.
Old 05-11-2012 | 09:47 PM
to the orig question. stainless bolts. nothing less. they are about 50 cents each.
