Go Back  Offshoreonly.com > Owners Forum > Sonic
Sonic owners what brand is you ladder and how is it mounted? >
Old 05-05-2012 | 10:13 AM
Default Sonic owners what brand is you ladder and how is it mounted?
Can someone tell me what brand ladder they are using and post some up close pictures of how it's mounted?
FuelinAround is offline
Old 05-06-2012 | 01:26 PM
Come on guys someone has to have something. Trying to get it on before memorial day.
Old 05-06-2012 | 08:24 PM
Jim Diesel's Avatar
"Unregistered Gun"
What I have seen is that sonic used a under platform mount like whats on a Baja outlaw swim platform. They mounted them with the bolts going all the way thru the fiberglass, believe they used like a pan head screw. And counter sank the head so you wouldn't snag your foot on it.
Jim Diesel is offline
Old 05-06-2012 | 09:44 PM
The one Jim Diesel is talking about is what I added to my Prowler. It's made by Windline, it's a 3 step telescoping ladder. They are the same as used on lots of Bajas, there is a red button on one side at the bottom of the ladder,push it in to release the ladder and pull it out. I mounted mine using stainless steel carriage bolts so the swim platform was relatively smooth. I'ld suggest pumping some 4200 in the holes, before inserting the bolts. I liked the ladder so much, I had Active Thunder install one on my 33.
509 SC is offline
Old 05-06-2012 | 09:51 PM
Plum_Crazy's Avatar
I dug up this old pic from the previous owner of my boat. I remember it used carriage bolts. I actually removed it and had the holes filled to clean up the appearance. My tie-bar is now down low by the trim rams, so I use that as a step.
Plum_Crazy is offline
