Backfiring under load
Old 06-27-2002 | 11:42 PM
Unhappy Backfiring under load
I have one of my 502 Motors backfing out the exhaust around 3000 RPM or higher every five to ten second. The motor also does not sound right while it is idling. I had a slight crack in the distributor cap I change it help a little but not much. I check all the spark plugs they look fine change the wire also. Just looking for some suggestions. I have a feeling one of the values is stuck? Or maybe a lobed cam. I can almost hear where it is. I am going to do a compression test tomorrow and see what happens.
cri331 is offline
Old 06-27-2002 | 11:55 PM
mxz800's Avatar
i dont think a compression test will tell wheather its a wiped cam lobe or not, espaecially if its the exhaust side. have you tried killing individual cylinders at an idle and seeing if it is located in one cylinder or the whole motor?
mxz800 is offline
Old 07-07-2002 | 09:49 PM
Smile BACKFIRING
I had a feeling that it was coming from the left side of the motor so I did a compression test on all the cylinders and the number 2 cylinder lost compression. So I took the head off and thank good it was just a value that was stuck so I replace all the value springs along with checking all the cylinders everything is fine and up and running.
cri331 is offline
Old 07-07-2002 | 10:49 PM
H2Xmark's Avatar
a trick i use that works well is put a vacuum gauge on a vacuum port on that motor, it should read a steady reading{unless a big overlap cam is used} if the needle is moving a lot, possible broke valve spring, cam lobe or valve problem, good luck
H2Xmark is offline
Old 07-07-2002 | 11:12 PM
BEAKBOY
I hate when she backfires under a load!
Old 07-14-2002 | 09:46 PM
Default backfiring
Thank for the information. I took the head off and replace the values and spring and everything is fine i had a bad value.
thanks
cri331 is offline
dukenrock
14
05-08-2007 06:39 PM
Shallow Minded
29
08-16-2006 11:57 AM
Mike L
2
07-24-2006 09:09 PM
dawezel
13
02-02-2005 07:24 PM
Miguel
31
03-27-2003 05:09 AM
