6.2L stalling at idle. Ideas? >
Old 05-07-2012 | 12:41 PM
Default 6.2L stalling at idle. Ideas?
Idling out of the marina yesterday, one engine cut out and would crank but wouldn't turn over. So I slowly cruised out to the cove on one engine.
Let it chill for about 20 minutes and she turned over. Runs like crazy once she's under throttle, no difference between it and the port engine.
When she idles, she has a slight miss. I think I am going to change the spark plugs, who knows when that was last done. Just got the boat in November with ~150 hours.
I have a spare cap and rotor at home. Ordering a fuel filter too. Anything else I should be doing before next weekend?
Just had my throttle cables replaced, could this just be a screwed up install?
Captain YARRR is offline
Old 05-07-2012 | 01:23 PM
Knot 4 Me's Avatar
If it runs fine off idle but does not want to idle it is most likely the IAC valve.
Knot 4 Me is offline
Old 05-07-2012 | 01:54 PM
Expensive Date's Avatar
Originally Posted by knot 4 me
if it runs fine off idle but does not want to idle it is most likely the iac valve.
+ 1 million
Expensive Date is offline
Old 05-07-2012 | 02:47 PM
Yep, IAC is bad.
Griff is offline
Old 05-07-2012 | 05:37 PM
Thanks guys...sounds pretty clean cut. Do you guys happen to know the part number?
Old 05-07-2012 | 06:07 PM
www.mercruiserparts.com Type in your engine and serial number, it will take you to a break down. You can also use a car one if you do a search on here I think it was mentioned in a thread. and buy two so you have one when the other one goes.
Old 05-07-2012 | 08:18 PM
Thanks so much. I think I found the thread:
http://www.offshoreonly.com/forums/d...iac-motor.html
Old 05-07-2012 | 08:23 PM
Make sure the pintle looks exactly like the one you take off
Griswald is offline
Old 05-07-2012 | 08:27 PM
Ted G's Avatar
Compare prices, last time I found a car one it was almost exactly what BAM gets for them.
www.cbpba.com
Ted G is offline
Old 05-07-2012 | 09:01 PM
bigboat28's Avatar
Also I was told if you take the little foam piece out on the new one they will not go bad. I was told that filter causes the problem. I took both out when I replaced my two.
bigboat28 is offline
