anybody have #5`s on a stepped hull
If you have a lot slippage or burnout during getting on plane ,there are some with #5,s that use a 1/2 inch ali plate with a offset bent ,and milled like a spacer that mount between the upper and lower .
This way the prop sits under a anti ventilation plate ,like a #3
I don,t have any pics ,and don,t know who the manufacturer is ... Ive seen it on skiraceboats that use a #5 several years ago
Buddy has them on a Black Thunder,,,,but has spacers to get them lower
I want to live in a world where a chicken can cross the road and not have its motives questioned.
I think my problem is i am too high I am 1.50 above the water line to center of prop turming 17.5 4 blade 32 pitch only got on plane a couple of times ,i already have cavitation plates like #6 custom made
as a spacer.also i am on stellings boxes
i would try and borrow a set of bigger props,,even if its a 1/2'' biggeer in diameter it should help.
I know a few guys with either 4s or 5s on straight and stepped vees. For getting on plane there really isn't a difference between the bottom types. All of these boats are on boxes and the highest one has the drives a little over 1/2 inch obove the bottom of the boat. All of the boats run between 17.5 and 18 inch diameter and 5 blades. The props have all been labbed to add cup for bow lift and aid in getting on plane. To get any of these boats on plane fairly quickly requires a 4000-4500rpm burnout. The boat (43 Nortech) with the 18 diameter and the props even with bottom can coax his out around 3500 rpm but it takes a bit to get up.
