Oil pressure 502 efi/mpi
Old 05-07-2012 | 03:14 PM
Default Oil pressure 502 efi/mpi
What kind of oil pressure is acceptable for these engines? I went for my first test run and both engines were between 25 and 40 depending on hot/cold, under load or idling, and I have slightly different reading for each engine. One runs a little weak on the pressure around 25 idle 38-40 under load while the other stays around 30 idle and 40 under load. Neither dropped below 25 or went above 40....
zschaefer38 is offline
Old 05-07-2012 | 03:15 PM
if it makes any difference i am using 15w-50 mobile one synthetic
Old 05-07-2012 | 03:49 PM
That's about where my 502 is at.
MCKILLOP is offline
Old 05-07-2012 | 05:34 PM
rule of thumb is 10 lbs for every 1000 rpm,normally they should be 60 lbs at max rpm 5200,but electric guages might be off.
mike tkach is offline
Old 05-07-2012 | 09:38 PM
Those readings are pretty normal for a 502mpi. I see about 35-40 cruising, 45psi at WOT and 20-30 at idle depennding on how hard I was running. 502mpi's also use oil due to the low tension rings. Expect a qt of usage every 10-15hrs or so.
Griff is offline
