Corsa Silent Choice >
Corsa Silent Choice
Corsa Silent Choice
Old 06-28-2002 | 10:44 AM
283CHECK
Default Corsa Silent Choice
I just got my boat back from the shop But they said that they noticed that the port silent choice is not opening, but if you reach back and help it by hand it will open. Does anyone know how much and were to find a silonoied? Or what the problem might be, they said they checked power out and it is getting the full 12V..
Chris
Old 06-28-2002 | 12:04 PM
Whiteknuckle's Avatar
Mine does the same thing on the port side only . Every once in a while it needs just a little help. It does it after the boat has set for a period of time. When I use the boat often, it loosens back up.
Whiteknuckle is offline
Old 06-28-2002 | 12:44 PM
Default exhaust
had same problem,replaced it[if i remember was about$25.00]and all is fine.was luckey that corsa is located on west side of town
mark linger is offline
Old 06-28-2002 | 08:38 PM
Lickitysplit's Avatar
Registered User
It just needs adjusting. I had two out of four develop the same symptoms last weekend. I posted a thread and got some good advice, do a search under "Corsa Silent Choice Mufflers" or "Lickitysplit". I also called Corsa and spoke with Dennis. If they are like mine the piston comes out of the solenoid. It has about a 3/4 in. long piece of allthread that you can use to adjust the piston. I had one that would not open, I adjusted the piston forward out of the actuator. Fixed it. The second one was chattering in the open position, that one I adjusted the piston back deeper into the actuator. Fixed it. I fiddled with them for a while, dropped the spring into the bildge etc....the usual stuff. But they are both fixed and work fine. Corsa's number is on www.corsaperf.com.
Mike
Lickitysplit is offline
Old 06-28-2002 | 10:10 PM
ROUGHSTUFF
I had to change one on my Sunsation, it is very easy. Just give Corsa a call and the will send you one. I remember it being about $40. You should be able to find their number in Powerboat or on the web.
DURANGOKID59
13
09-07-2006 02:47 PM
DURANGOKID59
08-29-2006 10:01 AM
35 White Lightning
Fountain
2
08-12-2006 03:33 PM
flipj5
5
03-31-2004 08:32 PM
edb07
3
07-22-2002 01:03 PM
