Drive Resevoir
Old 05-11-2012 | 12:08 AM
carter38's Avatar
Default Drive Resevoir
Does anyone having one of these laying around it's a discontinued item and I would really like to match my other one. Mine is leaking at the base.
Thanks!
918-232-3503
[email protected]
carter38 is offline
Old 05-11-2012 | 09:46 AM
Every one I have ever had leaked out the base at some point......what I did was drain it, clean all around the base, especially around the sending wires, dry with compressed air, and with the unit upside down, poured a small amount of epoxy resin all around the wires and let dry, hasn't leaked in three years now.
Way cheaper then buying one and it will eventually leak......
PS. I am assuming it is the stock Merc clear plastic one...? I can not open your picture. If it is not, disregard my blabber.....lol
FogduckerIII is offline
Old 05-11-2012 | 11:25 AM
I think I have one, I will look on sunday when I uncover the boat, I know I have 2 different types in there and I am installing 2 new ones this year. I will let you know what I have sunday night or monday morning.
Baja226sport is offline
Old 05-11-2012 | 11:17 PM
Carter38
Dont spend the money on a used one, espically if they have been sitting around. I found new replacement from Wholesale Marine online. Part # 69622A12 for $100 bucks. These have a new designed bottom aluminum block and dont use the float sender. I just used a step drill bit and enlarged mine to accomodate the float switch.
Hope this helps.
Aaron
Our Scarab 34 is offline
Old 05-12-2012 | 06:16 PM
I have on I pulled from my USA 39. If I remember correctly it is in pretty good shape. I do remember the vent on the top being rusty. I will take a pic and send it to you within the next day or so.
heavanie is offline
Old 05-12-2012 | 07:08 PM
i had those on one of my boats,i did a repair,and a month later the bottle cracked and leaked all over the clean bilge,i threw them in the trash and got some aluminum ones from teague,the polished ones,look really nice and no leaks.a buddy just went with imco scx drives and wants to sell his teague ones,pm me if interested,and il find out if he still has them.
mike tkach is offline
Old 05-13-2012 | 08:26 PM
carter38's Avatar
I'm interested let me know what he wants.
carter38 is offline
Old 05-14-2012 | 05:26 AM
Mike I'd be interested in the Teague ones if Carter passes.
jasonmd2 is offline
Old 05-14-2012 | 09:21 AM
he just got back to me,he paid 353.00 each,he will take 350.00 for the pair plus shipping,let me know if you want them.
Old 05-14-2012 | 09:25 AM
carter 38 has first dibs,if he does not want them,you can get them,half price,and he only used the boat 2 times,then installed the scx drives,that require the big imco res.
