Flex Exhaust hose >
Flex Exhaust hose
Flex Exhaust hose
Old 05-13-2012 | 11:39 AM
Default Flex Exhaust hose
Recently installed 496 exhaust on my 454 magnum. The risers are out of alignment with thru transom tips by about 2 inches. I have about 16 inches of hose between the risers and tips. Can the Trident flex hose be used in this situation and not burn through
hadleycat is offline
Old 05-13-2012 | 01:08 PM
Be careful not to have too much down angle at the riser. If there isn't enough clearance between the inside top of the hose and the top of the riser exhaust flare it will create a water shadow that will burn the hose.
NightHawk is offline
Old 05-13-2012 | 02:26 PM
Thanks, that is exactly what happened with the stock hose. I am wondering if I can bend the flex hose to the shape I need and have it stay that way.
Old 05-13-2012 | 02:56 PM
it doesn't like to bend. i have a kink in mine from down-angle of stock risers to up-angle of platform. thinking of fabbing wedges to change angle of tips to reduce the differance.
dereknkathy is offline
Old 05-13-2012 | 05:32 PM
I actually had to bend the top of the riser bell slightly to gain enough inside clearance when I replaced a 454 with a 496. Better than drilling new transom holes.
I use a 1 foot polished stainless steel tube with a Trident XHT bellows on each end rather than all hose.
Old 05-13-2012 | 08:16 PM
i fixed this same issue with a piece of 4" stainless tubing, cut angles on the ends to match the offset from risers to tips, made it 1/8" shorter than total length and used the hose as a coupling, this was done on a 454 w/ dana exhaust and it worked perfect and looked,sounded better as well
blownhammer2000 is offline
Old 05-13-2012 | 10:33 PM
so you basically made an elbow by cutting ends on a diagonal and put hoses on at that angle? sounds doable.
Old 05-14-2012 | 07:57 PM
exactly
Old 07-15-2012 | 01:59 AM
Default exhaust
Problem solved, I fabricated and Tig welded these up out of aluminum tube we had laying around at work.
Attached Thumbnails Flex Exhaust hose-p1010003.jpg   Flex Exhaust hose-p1010010.jpg   Flex Exhaust hose-p1010012.jpg
Old 07-15-2012 | 05:52 AM
watch out dude! you could find yourself making boat exhaust tubes for a living!! stainless would live longer. you know that judging by those welds. but you are in michigan. not salt.
