Bravo 1 Steering question
Old 05-13-2012 | 04:15 PM
Default Bravo 1 Steering question
How much side to side play should ther be on a Bravo 1 with power steering?
No hydraulics here, I wish I could swing it right now, but I can't. But I seem to have a lot of play side to side. The outdrive will move 6" to maybe 8" side to side and the steering wheel doesn't move.
fireguy is offline
Old 05-13-2012 | 05:11 PM
blue thunder's Avatar
Less than an inch. You have an issue. Most likely the tiller arm is wallowed out and the pin and arm need to be replaced.
blue thunder is offline
Old 05-13-2012 | 07:24 PM
seafordguy's Avatar
Worn out swivel pin?!?!
seafordguy is offline
Old 05-14-2012 | 01:42 AM
X2..........and this is a definate safety hazard that must be fixed.
http://www.jrmarine.com/products/gimbal_repair.htm
Griff is offline
Old 05-14-2012 | 06:27 AM
Bad swivel pin. Very common on Bravo's.
Redhook98 is offline
Old 05-14-2012 | 10:52 AM
Looked at it further and my Gimbal Ring is broken at the top. This SUX.
fireguy is offline
