valve cover
Old 05-13-2012 | 09:35 PM
Default valve cover
I have changed the cam for hyd roller on my 525sc and i dont know if the stock valve cover is enought tall for the new lift, i have 365 lift at cam with 1.7 rocker ratio = .620 lift at valve. the rocker is scorpion marine.
Anybody have try this lift number with that cover?
supermx96 is offline
Old 05-13-2012 | 09:43 PM
Are you running the finned covers? If so you should be fine, there is a lot of room under those covers.
endeavour32 is offline
Old 05-13-2012 | 09:48 PM
it will clear ,lots of clearance under the cover.
mike tkach is offline
Old 05-13-2012 | 09:59 PM
no thas is not the fine cover this is the blue one with the crome and mercruiser logo on top (525sc gen 6)
Old 05-14-2012 | 06:01 AM
If they have "drip tabs" in them they will probly hit. i'm at .630 lift with scorpions and had to cut the tabs off. i rolled the motor over by hand with with the valve cover mounted but not bolted down and i could see the cover moving around.
mine looked like this ebay auction.
http://www.ebay.com/itm/Mercruiser-4...3c96ff&vxp=mtr
gsxr1216 is offline
Old 05-14-2012 | 11:18 AM
There is plenty of room for that much cam lift under the stock valve covers. You may have to radius a couple corners on the rocker arms to clear the baffles around the fill holes.
The drip tabs are already ground off from the factory.
Griff is offline
