Fuel gauge issue. (WTF) GOT GAS? >
Old 05-23-2012 | 09:28 AM
Default Fuel gauge issue. (WTF) GOT GAS?
Replaced all my old gauges with new Livorsi gauges. Put the new fuel gauge in and it said full tank ran to 1/2 tank, then Guess what? Empty! ran out on the lake.. Yes I know should have checked the old gauge first..To excited with new gauges to pay attention... Other gauge worked fine.. Any thoughts? could the gauges be different in ohm readings?
silent lucidity is offline
Old 05-23-2012 | 10:02 AM
Possibly different ohm range, bad sender, wire issue.
hotjava66 is offline
Old 05-23-2012 | 11:41 AM
Dave M's Avatar
Veteran: Navy
Pretty sure Livorsi does selll their own senders that are compatible with their gauges.
Do people really rely on their gas guages?
I look at boat fuel gauges as a wild azz guess + or - 20%.
Dave M is offline
Old 05-23-2012 | 12:05 PM
Curious about this as well. What were your previous gauges? I have a 98 Outlaw that I just redid with all new Livorsi and my fuel level seems off from where it was prior to install. My old gauges were Faria.
drivrswntd is offline
Old 05-23-2012 | 12:07 PM
My fuel gauge is only close when the boat is on it's trailer, don't ask me how I found that out. Discovered the same day that 150' of anchor line doesn't mean squat in the middle of Lake Huron. LOL!!
ThisIsLivin is offline
Old 05-23-2012 | 10:22 PM
The sender probably just needs to be adjusted.
Griff is offline
Old 05-24-2012 | 03:18 AM
http://www.offshoreonly.com/forums/g...uel-gauge.html
NightHawk is offline
Old 05-24-2012 | 11:27 AM
My Livorsi senders have two small screws for adjustment, both of mine read full this year with just quater tanks after adding the first gas of the season. The proper adjustment procedure is to set empty level when empty and full level when full. I did the math to 1/4 tank with first gas and adjusted them to there...pretty close from what i can tell.
The screws are very sensative if you have them, just a hair turn will move the gauge a 1/4 tank
4bus is offline
Old 05-24-2012 | 08:19 PM
Talking
Well. I talked to Livorsi and they suggested that I fill the tank (ouch) then pull the sending unit let the float drop down and hook power back up and let set for at least 5 mins to zero it out. Should read empty. Then put back in full tank and it should set the upper limit with it being full... Not sure how but hey I'll give it a whirl Ya-all.
could this be like snipe hutting?
