Help with tool to get dash off??
My speedo doesn't work. I'm hoping to blow some compressed air through the line from the back of the guage but I can't find the right tool to get the dash off. The fasteners are torx shaped but not quite. Take a look at your baja dash and you'll see what I mean. Anybody find on of these tools? Where did you buy it?
I know what you mean, the screw has a hex(torx) style head, but there us a little nipple for lack of a better term in the middle, requiring a similar tool with a hole in it.
I found my set of these bits in Lowe's.
through snap on tools.
Gottahaveit,
You make a good point. I have the tool, but it's not one of the ones I keep on the boat. I should reconsider that...It would suck to limp home from 10 miles away because the damn speedo tube came off......
Yo, before you go to all the trouble of pulling the dash out, pull the speedo tube off the outdrive and gently blow a little air into the line to see if the tube or the pickup is clogged. Speedo needle should jump a little with light air pressure. Do not blast away, because you don't want to jam something into the back of the speedo guage. This may save you pulling the dash panel, all though it ain't that big a deal anyway.......
