Replacing shift cable bellow - anybody know? >
Old 06-03-2012 | 08:38 PM
Default Replacing shift cable bellow - anybody know?
According to my Merc. manual, it says to just disconnect the end fitting at the engine side (which I've done), remove the spiral wrap inside the boat, and pull the cable out from the transom. It doesn't mention any other operation.
But, as in the pics, the cable at the engine has a barrel and a nut. The barrel looks to be permaswaged on at two points, so not sure about unthreading it.
At the transom end, obviously it's too large to fit through the bellow.
Anybody know how to do this?
puzzleboy is offline
Old 06-03-2012 | 08:48 PM
The threaded barrel should unthread from the brass cable end.
whoya is offline
Old 06-03-2012 | 08:52 PM
If you don't have the correct plyers for the metal clamp (shift cable boot) you can use just a zip tie, I know marinas that just do this. Thats what on mine and been holding fine for years. Last boat I did I used a pair of plyers the best I could for the clamp and used a small zip tie next to it.
whoya is offline
Old 06-03-2012 | 09:04 PM
a clever guy can put the shift cable bellows on without taking the cable out .takes a little time but it will go over the end of the cable on the bellhousing side .done it many times when in a hurry and the boats gotta go
smokin' gun is offline
Old 06-03-2012 | 09:14 PM
How's that? I would think there's a risk of tearing it on the hex, as it's much larger than the bellow i.d.
What's bizarre, is that Merc could have used a much smaller hex there, to enable this easily.
Old 06-04-2012 | 04:35 PM
loosen the jam nut, the threaded section where the
barrel is will then screw out.
JaayTeee is offline
Old 06-04-2012 | 05:01 PM
Biggus's Avatar
Replace the whole aft shift cable as they typically get damaged when pulling it out. Be sure to make a snake from the old inner cable to pull the new one back through. -Otherwise, you are in for a headache getting the new cable back in and routed correctly.
Biggus is offline
Old 06-04-2012 | 05:13 PM
Ted G's Avatar
+1
Unthread that barrel then pull the inner cable out, leaving the outer housing in place. Now thread the inner cable back into the housing from the engine side. When you pull the outer housing hold the inner in place and then thread the new outer onto the old inner and up to the engine. Then pull the old inner and push the new inner up from the transom side.
www.cbpba.com
Ted G is offline
Old 06-04-2012 | 11:37 PM
Just curious, why would it get damaged? Thx!
Old 06-05-2012 | 04:08 AM
Biggus's Avatar
Many times you have to tug on it pretty hard to get it out. -If it's factory, there's a spiral protective wrap around the outer jacket down low that gets bunched up when pulling it out. They don't last forever. When it's time for the shift bellows, everything else back there is on the way out too.
Biggus is offline
