Thru hull exhaust
Old 06-05-2012 | 07:32 PM
cig28's Avatar
Default Thru hull exhaust
Guys need some help on how I should
go about drilling new exhaust holes, should i do it from the inside or outside and what is the procedure. Thanks
cig28 is offline
Old 06-05-2012 | 07:44 PM
You can do it from either side, If doing it from the outside you need to put a few layers of masking tape all around where you'll be drilling to be sure you don't mark up anything you didn't intend too. If your hole saw isn't deep enough to go all the way through you'll need to stop 1/2 way and pry out the 1st piece (either out of the hole saw or transom) If you already have pipes and did your measurements from the inside, just use a long 1/4" bit from the inside (at the same angle of the transom) to mark the spot on the outside...
fastdonzi is offline
Old 06-05-2012 | 08:00 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I like to cut thru from both sides. Gives a nice clean cut, no splinters or chips
US1 Fountain is offline
Old 06-06-2012 | 02:24 PM
anewway's Avatar
Also, in addition to the masking tape, run the drill backwards a minute or two when you first start, and this will help eliminate any chips when you start. Once you have a nice groove started, switch back to forward and hop to it.
anewway is offline
