Need Ignition and wiring harness
When I got my 22 Velocity it had a 454 MPI that needed some work. I just pulled it to replace it with my 468 carb'd motor that I know is ok. I need a engine wiring harness for a BBC carb'd engine since I don't want to start hacking on the EFI harness. I also need a MSD box, mine got burnt when my last boat caught on fire. Any help would be appreciated. Thanks.
Dont cut on the harness...just use the connections that you need and tape and tie all the other stuff up. I have done this many times. Mercruiser wants something like $360.00 for a wiring harness like you want for a carbed BBC...way out of line on the price for some wires.
After talking to a few a people I have decided to run the stock ignition system and try the MPI harness. Smoking gun if I have any issues I will PM you to get your harness. Sonic what did you do to get around the roadblock? When I was talking to some friends this weekend they questioned whether not having all the connectors hooked up would put it in guardian mode and I guess after your post its possible.
