Marine Air Generator Question >
Old 06-11-2012 | 03:30 PM
Default Marine Air Generator Question
I've said I would never do it, because I always thought it was such a band aid, but I've considered purchasing a Honda generator to use while on anchor overnight to run the Marine Air system that came factory in my Fountain. Use would be minimal, and only to run A/C. Does anyone know what size I could get away with? I see they make a eu1000, but not sure if that'd be enough. Any input? I can't necessarily justify the cost, or weight of a marine genset for the 1 out of 99 times I'll use it.
Jpzaluski is offline
Old 06-11-2012 | 03:34 PM
TRL505's Avatar
Ask Freaky Fast...he has a custom setup he did...it is pimp....kind of...ok..maybe not.
TRL505 is offline
Old 06-11-2012 | 06:00 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I have A MERMAID 6500 btu in the Fountain that will run off a 1000W, according to Mermaid.
My cruiser has a 10k unit. That one needs 2000W
US1 Fountain is offline
Old 06-11-2012 | 06:11 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Honda EU2000i will work fine.
Sydwayz is offline
Old 06-11-2012 | 06:49 PM
Is the 1000 watt too small? Do I have to worry about exhaust burns or discoloring on the back of the boat? If that's even a risk I don't want to do it.
Old 06-11-2012 | 07:05 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Nah, the RPBA has been doing this for years, probably 10 of us total. You can put it on the swim plaform and just angle the tiny exhuast away from the boat. If you are going to ride the hook for the night, you might want to put a ratchet strap across it just to be sure. They work perfect for this.
Do a search on here on "EU2000i". Almost everyone runs an external genny like such uses the EU2000i. Hell, ETicket even installs them in the bilge.
There is also a "hard start kit" which is basically a resister that keeps the genny from dying if the compressor is just a shade to much for the genny to handle when it kicks in.
Sydwayz is offline
Old 06-11-2012 | 08:26 PM
Ginger or Mary Ann?
W/o knowing what size AC unit you have, no one can say what size gen will work. As stated earlier, my 10k unit needs a 2000W gen, where as a buddies 12k unit needs 2 2000W ran in parallel. We tried the a hard start on his last month as he is right on the edge, didn't work for him.
What size AC??
Old 06-11-2012 | 08:58 PM
US1.... that's part of my question. I have no idea what size it is, I just know that it is the factory installed unit from Fountain. I would assume they would have always used the same?
