motor never gets over 115 degrees. ok?
all new gauges and senders plumbed in the intake. running b&m blowers with no thermastat and a cross over.
do i need to get my temps higher some how or running like this be fine?
You will need also a bypass hose between the cross over and the th housing to get enough water in exhaust when the th is close. The bypass is the reason that you need to drill hole in (stock merc) thermostat because the thermostat is afected by the cold water coming in front of them.
Hope that's help.
