GM / Power steering pump - or Merc >
Old 06-18-2012 | 12:15 PM
Default GM / Power steering pump - or Merc
Does anyone konw if you can use a GM - power steering pump, instead of a Merc?
GM - $50
MERC - $600
eriknelson is offline
Old 06-18-2012 | 12:37 PM
Strip Poker 388's Avatar
Rob
GM - $50
MERC - $600
if its the old design i would think it would not be a prob,make sure you reuse your ck valve,they have diff orifices. And ck the inlet and outlet if there in the right place
here a pick of old style tank,car
Attached Thumbnails GM / Power steering pump - or Merc-img_0332-custom-.jpg
Strip Poker 388 is offline
Old 06-18-2012 | 07:23 PM
Just did this a few weeks ago... Take yours to Pep Boys (or wherever) and have them get GM pumps out of the box. Some have different return lines you can choose from, just leave the unused one plugged. Pay attention to mounting locations and you should be fine. But yes, take the regulator out of your pump where the pressure line connects and insert in the new pump. Local marina says that the new pumps come to them in an AC Delco box with a Merc sticker on it... and a $500 mark up. Yikes.
wexrocks is offline
Old 06-18-2012 | 10:04 PM
thanks - where is the regulator on the pump? can i buy just a new regulator?
Old 06-18-2012 | 10:35 PM
its behind the large fitting where the pressure line screws in to. I doubt that it can be purchased separately.
snapmorgan is offline
Old 06-18-2012 | 10:44 PM
Randy Nielsen's Avatar
I replaced the new style pump on my 496 mag with a 89 corsica 3.3 liter pump just had to swap the fitting for the remote reservoir and of course the regulator. just for info on this style of pump, saved enough to fill my tanks & go boating!
Randy Nielsen is offline
Old 06-18-2012 | 11:00 PM
Don't get an auto zone pump. Went through three that leaked and finally got a pump from an O'reilys I believe it was that worked great. I kept reusing the pressure relief valve from the original pump also. Iirc the pump was for an 80's Chevy truck.
adrenaholic1 is offline
Old 06-19-2012 | 01:17 AM
good info....thx
pqjack is offline
Old 08-11-2012 | 10:35 PM
I also just got an automotive pump and have a question about where the regulator is. Just to clarify it is the big nut where the high pressure side screws into the center of the nut? Thanks
jbizub5192 is offline
Old 08-11-2012 | 10:42 PM
c_deezy's Avatar
Yes.
c_deezy is offline
