Go Back  Offshoreonly.com > Owners Forum > Powerquest
Garboard Drain Plug >
Garboard Drain Plug
Garboard Drain Plug
Old 06-24-2012 | 09:32 PM
Default Garboard Drain Plug
My Powerquest is leaking water. I think it is coming in around the Garboard Drain Plug & its plate. When tightening the plug into the plate. The plate & its 3 screws give a little when tightening the drain plug into the plate. I am assuming the chalk or adhesive between the plate & the hull has broken its seal & letting the water in. My question is, if I unscrew the 3 screws holding the Garboard Drain Plug on, clean out the adhesive or chalk out. What adhesive or chalk do I use to put it all back together ???
Tom !!!
ibhottubn is offline
Old 06-25-2012 | 02:11 AM
5200 sealant
PQKEV is offline
Old 06-25-2012 | 09:24 AM
Mentalpause's Avatar
Probably want to get your transom tested for moisture content.
Mentalpause is offline
Old 06-25-2012 | 10:07 AM
rchevelle71's Avatar
Trying to figure out why one would use chalk in there Maybe that is why it is leaking, chalk doesnt do good with water, I would remove it, and replace using caulk this time, preferably 4200 or 5200
rchevelle71 is offline
