454MAG MPI 5v reference? >
Old 06-25-2012 | 11:52 AM
Default 454MAG MPI 5v reference?
I am looking for anything I can pull 5 volts from on my MPI, I am installing a electronic fuel pressure sending unit and it needs 5v reference, not sure if any of the Merc sensors on this motor use 5volt or not........HELP
stopdropanroll is offline
Old 06-25-2012 | 10:03 PM
does the fuel pressure guage have power supply module available, i would use that. the 5v ref is set for the senders in circuit, 5.1 or 4.9v can cause troubles, newer engines will set guardian. tapping into that circuit may lead to quirks during operation.
keith2500hd is offline
Old 06-26-2012 | 07:59 AM
Good point, my Gaffrig gauge does not have a supply, I may just go to a mechanical sending unit.
Old 06-26-2012 | 08:08 AM
here you go
http://www.ebay.com/itm/5-Volt-5V-DC...-/290592255754
sutphen 30 is offline
