28 twin starter motor removal question >
Old 06-26-2012 | 10:00 AM
Default 28 twin starter motor removal question
Need to pull the starter off the port engine on my 28 twin big block. I am thinking I may (hopefully) be able to reach it if I pull the manifold and riser off on the starter sided. Is this possible or do I have to hoist the engine up?
Prostreet144 is offline
Old 06-26-2012 | 02:54 PM
CIG3's Avatar
I'd pull both inner exhaust manifolds. should have plenty of room then. May sound like alot of work but will be faster in the end. Plus you'll be able to walk the next day.
CIG3 is offline
Old 06-26-2012 | 03:49 PM
+1, might also be able to pull just the port inner side elbow and engine hatch so you can come at it from the stern..........but you need a swim platform to work off of.
TexomaPowerboater is offline
Old 06-26-2012 | 06:27 PM
jimjomack's Avatar
I pulled my motor and rebuilt saltwater pump the same time.
jimjomack is offline
Old 06-26-2012 | 10:04 PM
i just did an exhaust on my 28 twin. with the manifolds off there is plenty of room to get in there and get it out. the starboard motor is the one i would be dreading
88bullet is offline
Old 06-27-2012 | 08:53 PM
Thanks for the help. Pulled the exhaust on the port engine and the starter was very easy to remove. Took a little less than an hour but boy does my back hurt. Found a busted nose cone on my MES mini starter. Not sure how this happen. I will be calling them in the morning.
