Speedo tube won't stay on? >
Old 07-03-2002 | 10:19 AM
Dock Holiday's Avatar
Charter Member #34
Default Speedo tube won't stay on?
I'm having problems keeping the speedo tube on my new Baja 36 Outlaw.
The tube blew off the plastic fitting on the outdrive during the first dealer water test around 69mph. They double clamped it back on I ran around all weekend in the low to mid 60's with no problem. Made one full trottle run Sunday and it blew off again around 70mph.
Where do you guys think the real problem is?
Wrong clamps? Bad plastic fitting in the drive? Problem forward with tube or speedometer?
Everything works great until you hit the 70MPH mark?
Would like to fix it one last time, the right way.
Any suggestions are appreciated.
Mark
Dock Holiday is offline
Old 07-03-2002 | 10:22 AM
aTX427's Avatar
They are garbage to begin with. Go GPS.
aTX427 is offline
Old 07-03-2002 | 10:25 AM
CigDaze's Avatar
Hey Boss,
This also happened to me repeatedly right at around 55(indicated). I would put it on, only to fall off again...
Final solution: I put a small tie-wrap around the tube on the little fitting in the drive...problem solved, hasn't blown off in over a year.
CigDaze is offline
Old 07-03-2002 | 12:03 PM
Tinkerer's Avatar
Another thing that works is shrink tubing. cut small lengths (about 3/8 inch long) and put them over the tube after it is installed on the barb and then shrink it. I do two layers.
Tinkerer is offline
Old 07-03-2002 | 12:29 PM
Charter Member #34
Thanks Guys,
I will try the tie wrap first.
I agree, the GPS is the way to go. I need to check and see if they offer a Monster series speedo in the GPS style.
Mark
Old 07-04-2002 | 12:09 AM
mcollinstn's Avatar
shrink wrap is the only reliable fix. Make sure you use a short piece that does not go past the hose barb, or else it will shrink the tubing closed and the speedo wont work. Use the thick kind of shrink, not the cheap thin pvc stuff.
mcollinstn is offline
Old 07-04-2002 | 10:47 AM
mxz800's Avatar
so how is the new boat runnin other than this glitch? have you been able to get any GPS top speeds yet. have you been able to get that grin to wipe of yet
Rob
mxz800 is offline
Old 07-04-2002 | 10:55 AM
eliminator219's Avatar
Default Loss at 70
Baja Boss,
Just stay at 69, Not a bad place to be!!
eliminator219
eliminator219 is offline
Old 07-05-2002 | 08:17 AM
Charter Member #34
Rob,
The boat is running GREAT. Other that the speedo thing no problems.
The Grin is permanently afixed. I have not got any GPS numbers yet. During the run when the speedo tube came off we were running with a friend that has a 38 Fountain sprot cruiser with GPS speedo. He was at 68 MPH on GPS and we were blasting by him pretty quickly.
eliminator219,
Yeah, 69 is a good place to be. I should have named the boat "Go N 69".
Thanks guys.
krmp
Fountain
1
10-14-2008 11:57 PM
big jing 2
3
03-18-2007 03:50 PM
klaw
2
07-07-2004 02:05 PM
steve chalupka
Sonic
15
02-13-2004 11:37 AM
kaamacat
5
07-26-2003 10:51 PM
