Go Back  Offshoreonly.com > Owners Forum > Sonic
1999 Sonic 260 >
1999 Sonic 260
1999 Sonic 260
Old 07-03-2002 | 11:06 AM
Checkmate283's Avatar
Default 1999 Sonic 260
What is a 1999 Sonic Prowler worth with a HP500 carb, 99 hours,depthfinder,silent choice and trailer. Dealer is asking 59k.
Checkmate283 is offline
Old 07-03-2002 | 03:18 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I have a 1999 Prowler HP500EFI. Call me and we can discuss.
703.352.7925
Brian
Sydwayz is offline
Old 07-03-2002 | 03:37 PM
Sydwayz...thanks for the phone call!
Old 07-03-2002 | 04:49 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
No problem. Anytime. The 260 will not disappoint you. The room inside and the ammenties are unparalleled in a boat this size. I hardly ever use my tabs. It definately thinks it is a bigger boat when it gets out in the rough stuff. I did five+ miles, throttle on the dash, a few weekends ago, in consistant 3-4 footers on the Potomac; not one sneeze. That was the first time I really wished I had 250 more HP. It is heavy, and be prepared for that when you go to tow it. 102 gallons of fuel adds up too, (600+ lbs). (My boat with a full tank of fuel, all gear, and both covers, on the trailer, weighed in at 7280 lbs!!!) If you go to www.sonicboatsusa.com, and look at the specs, they are still the same as the 99 you are looking at. There are several of these boats in NY who are owned by members of this board.
Sydwayz is offline
Old 07-03-2002 | 11:08 PM
Dano's Avatar
I have a 2001 496Ho I'll deal on! Just water tested a 2003 w/500EFI and ITS pretty nice ride...I do like that ITS set-up on that boat
Dano is offline
Old 07-05-2002 | 08:31 AM
Whats ITS?
Old 07-05-2002 | 08:45 AM
ITS is a 7" set back integrated transom system with hydraulic steering built in. It is brand new from Merc and promises to be a great addition. It should add a mile an hour on the right kind of hull and is only available with the XR/XZ drives.
Hope that helps.
Vyper340 is offline
Old 07-09-2002 | 07:35 AM
mlitefan
pureattitude240...Is that the one advertised in the boat trader from Maryland?
I looked at that add and wondered the same thing. I think it listed the boat at a 75+mph??? Is it really that fast with that much weight?
Old 07-09-2002 | 04:27 PM
Mark in So. MD's Avatar
75mph, maybe close, but nope. Sydwayz can atest to that. I am curious as to the speed Dano saw with the 500EFI/ITS.
Dano was it the newer hull design, well i shouldnt say new hull, i meant, same mold but different layup?
Mark in So. MD is offline
Old 07-09-2002 | 06:00 PM
26sonic's Avatar
have a friend with new 2002 26 prowler with 500efi and its , runs 75mph on gps with bravo 26p labbed prop. boat runs 75 %out of the water with just a small part of stern in the water don't know if i like it or not prefer maybe with out ext. box.
26sonic is offline
