Gil Manifolds & Dry tails Bravo Standard
I have a set of Gil (not mercruiser gil, actual Gil offshore) manifolds with long dry tails that I was going to use on my Scarab but I changed my mind.
Just looking for what I paid, $900
They are standard height, bravo set up. I will include a set of transom rings as well.
From the front of the flange to the end of the pipes is about 34" and from the base of the flange to the top of the riser is about 5"
Last edited by Baja226sport; 07-06-2012 at 03:06 PM. Reason: pics and measurements added
I want them as long as they will work can you send pics please to [email protected] or text 410 241 5796
Also, 1 picture show the length compared to a long wet riser.
These pipes have been completely closed off at the end. ZERO water mixes with exhaust so they are EXTREMELY loud. The 3 holes in the bottom of the pipe are where the water exits. This is a modification that was done by Hardin Marine.
NOT ROT OR CORROSION ON THESE MANIFOLDS!!! I would spray them with fresh paint though, they are scratched from being moved around the garage alot.
Thanks, looks close to what I have. I bought a set that the guy wasn't positive was for a bravo but took a chance. Cant find the overall length of tails confirmed to be for a bravo setup anywhere is all. No problem if you don't have this...should know this week if they fit one way or another lol
