#6 Questions
Looking at the cutaway in this link, I assume this a RH drive.
http://www.offshoreonly.com/classifi...o41216-en.html
How is a LH lower different? Are the 2 gears on the propshaft set inbetween the 2 vertical shafts? Doesn't appear to be enough room.
Other question is how do #6's stay cool spinning huge power and high RPM's, with nothing but the skeg in the water?
Bravos at least have some internal water, the bullet is in the water, and some add drive showers. #6 has none of these.
Yes, the propshaft gear is in between on the older drives. It is a short double sided gear. The newer drives change the rotation in the upper by putting the driven gear at the top or the bottom of the housing.
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
