No Thermastat..? >
No Thermastat..?
No Thermastat..?
Old 07-07-2012 | 03:20 PM
Default No Thermastat..?
Is it ok to not run a Thermastat? The boat is a 97 baja hammer with a carbed 454.
Tf705 is offline
Old 07-07-2012 | 03:39 PM
You need a stst. Do not run without.
toolsinbox is offline
Old 07-07-2012 | 06:01 PM
c_deezy's Avatar
I don't run a thermostat. 1996 Carb'd 454.
I've tried a 140 and a 160, all they did was increase my water pressure and oil temp due to decreasing water flow, didn't really notice a temperature change at all.
It all depends on how cold the water you run in is. If you are in cold water, I would consider using a thermostat.
c_deezy is offline
Old 07-07-2012 | 06:07 PM
Fenderjack's Avatar
Pirate of the Chesapeake
Depends on where you run at. For us up here in the chesapeake alot of us do not run with one. Never any issues.
John jr
Fenderjack is offline
Old 07-07-2012 | 06:51 PM
mass here no therm runs great
mach1magnum is offline
Old 07-08-2012 | 06:30 AM
irs not a matter of how well it runs, its a matter of how long it lasts. the ring wear and bore wear will be exponentially worse if you run the block too cold.
not to mention that the running clearences will be big and wear the pistons out as well...
there is a reason there is something called " operating temperatures" and why they aren't called " yes it will run but youll rebuild it at 1/3 the hours" temps
do what you have to do to get the temps to 160 at a minimum
stevesxm is offline
